Traction Kubota M6800 With Cab...Front Differential Hard to Lock In
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
Been really difficult to operate the lever to lock in the front differential on my M6800 with cab. I briefly got under the tractor tonight and couldn't see anything bent or broken. I sprayed everything with a light lubricating spray while I was under there but didn't notice any improvement.
Help.....
td
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #2
It was quite a PITA to get my M6040 into 4WD until I had operated the lever many times. Your situation sounds like mine - its simply a matter of new gears, levers & systems meshing, mating and operating together. While pulling on the lever - gently shift the tractor from forward to reverse and allow it to move slightly in both directions. Time & use should make this operation improve.
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #3
May not apply since it's a much smaller tractor, but on our B2910, a little reverse pedal to engage the front axle and little forward pedal to disengage seems to help quite a bit.
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #4
If you have a loader on raise the front wheels slightly to take the pressure off of them, it should slide in a lot easier
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #5
engage while in motion
   / Kubota M6800 With Cab...Front Differential Hard to Lock In #6
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
DEUTZ MARATHON...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
Hyster Forklift (A55973)
Hyster Forklift...
