Kubota M6800 shuttle shift issue
   / Kubota M6800 shuttle shift issue #1
ufcxl
Central Texas
JD 5085E
Help? I was pulling a full tank sprayer thru a creek crossing. back tires need replacing meaning I could not get up the other side. After several tries and rolling back in N, my shuttle shift won't go into R. In fact it would not fully go to N and engage the starter cutoff. Had to pull the plate and access the plunger cutoff manually to start.
Any thoughts on what my issue might be?
   / Kubota M6800 shuttle shift issue #2
Sync or hyd shuttle?
Hmmm.. not sure I know the difference. I think Sync? THe F-N_R shifter is on the dash next to the steering column. Connects to a linkage under the column then on to the trans. Cutoff is right there under steering column.
   / Kubota M6800 shuttle shift issue #4
Hydraulic Shuttle should have decal on the hood, both have the similar FNR lever, sync shuttle requires clutch to shift F-R, hydraulic shuttle is clutchless.
   / Kubota M6800 shuttle shift issue #5
Hydraulic shuttle is also much better. No dry clutch in the bellhousing to wear out. Clutch pedal is strictly optional on both mine.
Mine are via cable, not linkage. Makes sure your linkage is free or the cable lubed.
   / Kubota M6800 shuttle shift issue #6
Yup.
Check your linkage carefully. If it's similar to my M4700 it could be jammed with a twig.
I wrote about a similar problem about a year ago.
I will check for a blockage or something binding. THanks for the thoughts
2018 East Texas 20ft Utility Trailer (A49461)
2018 East Texas...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A51039)
2022 Down2Earth...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
