Kubota M6800 shuttle shift issue
   / Kubota M6800 shuttle shift issue #1
ufcxl
Central Texas
JD 5085E
Help? I was pulling a full tank sprayer thru a creek crossing. back tires need replacing meaning I could not get up the other side. After several tries and rolling back in N, my shuttle shift won't go into R. In fact it would not fully go to N and engage the starter cutoff. Had to pull the plate and access the plunger cutoff manually to start.
Any thoughts on what my issue might be?
   / Kubota M6800 shuttle shift issue #2
Sync or hyd shuttle?
Hmmm.. not sure I know the difference. I think Sync? THe F-N_R shifter is on the dash next to the steering column. Connects to a linkage under the column then on to the trans. Cutoff is right there under steering column.
   / Kubota M6800 shuttle shift issue #4
Hydraulic Shuttle should have decal on the hood, both have the similar FNR lever, sync shuttle requires clutch to shift F-R, hydraulic shuttle is clutchless.
   / Kubota M6800 shuttle shift issue #5
Hydraulic shuttle is also much better. No dry clutch in the bellhousing to wear out. Clutch pedal is strictly optional on both mine.
Mine are via cable, not linkage. Makes sure your linkage is free or the cable lubed.
   / Kubota M6800 shuttle shift issue #6
Yup.
Check your linkage carefully. If it's similar to my M4700 it could be jammed with a twig.
I wrote about a similar problem about a year ago.
I will check for a blockage or something binding. THanks for the thoughts
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
