Kubota M6800 fuel bleeder cock
   / Kubota M6800 fuel bleeder cock #11
overall, the pre Tier4 M series utility tractors are fine machines. sounds as if the M6800 will handle the hay harvest just fine.
   / Kubota M6800 fuel bleeder cock #12
When air conditioner clutch was inoperable on my JD 4255 I pulled my JD 467 rd baler making 4X5.5 bales with my Kubota M7040(64 pto hp) on virtually flat Texas soil with no problems
   / Kubota M6800 fuel bleeder cock #13
I believe you can run a round bailer with a low power tractors, so long as it's flat terrain. The issue arises when it's hilly. My M9 never sounds like it's laboring, in fact I don't even run it at 540 when bailing, more like 400 pto. Netting don't depend on pto speed with the BV. It senses the total wraps electronically and the density is also controlled electronically. I do like the fact that I can start a bale with a soft center and then crank up the density as the bale grows and unlike my old New Holland, it's easy to get an even fill. The readout screen has a superimposed steering wheel on the screen and you steer the tractor following the steering wheel on the screen. Finally, unlike the miserable net insertion the new holland had, net insertion is quick and easy plus the BV carries a spare roll of net above the net wrapper so when you run out of net, you just tell the bailer to insert the next roll and it does automatically, no touch on my part. Carries 3 extra net rolls on the side (left side) and 8 balls of twine on the right side that I've never used anyway. I may at some point just to see how well it twines a bale. Unlike the NH that had parallel twine arms, the BV has overlapping twine arms so I'm kind of curious how it wraps. May try it out sometime, just for kicks and grins.
Speaking of net, it really went up in price this year.
   / Kubota M6800 fuel bleeder cock #14
How many yrs have you baled with your Kubota rd baler? How many bales have you baled with it? Other than Kubota having to install silage scrapers did your baler have any other problems requiring a dealer service call? How much is a roll of net costing this year? Last 4 ft net I purchased was $320 & it was 13,200ft in length.
Lonestar Panels (A49339)
Lonestar Panels...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A46683)
2006 GMC C8500...
2008 Ford F-250 Crew Cab Pickup Truck (A46684)
2008 Ford F-250...
Double Bottom Turn Plow (A48837)
Double Bottom Turn...
Case 445T Skid Steer (A49251)
Case 445T Skid...
2021 Chevrolet Equinox SUV (A46684)
2021 Chevrolet...
