Kubota M108 3PH priority
/ Kubota M108 3PH priority #21
With a check valve & next the accumulator, between the remote outlet and the hydraulic motor, the accumulator will charge to the operating pressure of the hydraulic motor. When the flow from the rear remote stops, the accumulator starts to discharge as the pressure drops. The check valve ensures that the flow is towards the hydraulic motor
You don't want to nor can you raise the accumulator pressure higher than the operating pressure.
Yes accumulators are more commonly found on closed center systems but then those systems are usually on more sophisticated pieces of equipment.
To me this is a simple solution for an uncommon problem.
Dave M7040
Ok, I was missing something (not unusual). My brain was stuck on using the accumulator to raise the 3PH. What you propose should work.
/ Kubota M108 3PH priority #22
I sized what I believed would be the appropriately sized accumulator which was the solution I was proposing.
I asked Parker Hydraulics for a quote.
List Price - $4,512.00
Lead Time - 30 working days
Obviously my great technical solution becomes impractical when you add the cost.
Dave M7040
/ Kubota M108 3PH priority #23
Does Kubota offer flow compensation on any of their tractors? I know some have pressure compensation, just curious.
2023 Kubota M5-091D 4WD 92HP Utility Loader Tractor (A66734)
2023 Kubota...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2009 ALLMAND  MAXI-HEAT MH1000 HEATER (A68842)
2009 ALLMAND...
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2022 Sany SY35U Mini Excavator (A66734)
2022 Sany SY35U...
