Kubota M Series 3 Point Control Lever Extension
   / Kubota M Series 3 Point Control Lever Extension #1
walker450
Platinum Member
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
Anyone who has a Kubota 40 series M has probably wished the 3 point control was further forward. When I bought the tractor I removed the right side armrest to make it easier to get to. The control, when in the raise position, is where your elbow is if you are sitting with your arms in a normal position. It is also crowded against the fender and is just plain awkward.
I built an extension that bolts on so it is easier to use now.
I used 11 guage sheet metal and welded it together and put the factory grip on it. I also bent it at a slight angle so it is further from the fender and at a more natural position. I use my 3 point box blade a lot so this was well worth the hour it took to make this.
   / Kubota M Series 3 Point Control Lever Extension #2
I like that. 👍
Both to get it in a better position, but also to differentiate it from the draft control when you're busy grabbing levers. My 3 controls are just ahead of the 3pt controls and my right hand can get very busy.
   / Kubota M Series 3 Point Control Lever Extension #3
I like that too - can see how that would be much better. My M5640 operators station is set up with the control farther forward and closer to the fender so it is good for me but one thing I didn't like was that I could not see my lift arms when standing on the ground operating the control lever. The rear tire blocked my view. Made it harder to mount and adjust implements. Lots of walking around the tire to take a look. So I put an extension off the linkage that comes out by the 3ph. It's the bar sticking up at a 45 to the right of the remote couplers,
gg
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52708)
KNOW BEFORE YOU...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
