Loader KUBOTA LOADER
/ KUBOTA LOADER #1
Ghive
Coshocton, OH
Kubota L345DT & B3200
HEH GUYS
CAN ANYONE TELL ME WHAT LOADER IS ON THE L345DT ?
THANKS
/ KUBOTA LOADER #2
TractorData.com says its the Kubota L1720 loader.
/ KUBOTA LOADER #3
That is a big loader for a 40HP tractor. My M4700 only has an LA1001.
Seems like another TBN'er thoght the same about 7 years ago:
My first L345DT had the model 1720 loader. It was made in the U.S. I always thought it was too big & heavy for the tractor. It's length put the load way out - steering was hard. It wasn't removable so the bulk and weight were always there. Here's what it looked like:
I've been looking for a better-matched loader for my current L345DT.
A new-in-the-crate LA450 loader came up on eBay. This loader was designed by Kubota for the L models that came out in 1985, and whose bell housing and tranny case were very similar to the 1982 models. It looked like it might fit or come close - so I went for it.
The hunch was right - the center frame bolted right up to the six holes in the bellhousing without modification. The front support needed one new 1/2" plate welded in for bolting to the frame - $50 mat'l & labor including orange paint.
So here it is - a restored L345DT with a new removable Kubota loader. It uses the internal hydraulics accessed at the hydraulic block under the seat. (regular 3-hose setup with the power-beyond hose coming back to the block)
I'm one of only a handful of people who thinks this is cool - but I'm quite pleased about how it came together.
That OP is still active.
/ KUBOTA LOADER #4
Good info there newbury. That does look to be overly large for the tractor. Strange - wonder why TractorData would recommend such a large loader.
/ KUBOTA LOADER #6
TractorData simply reports what was supplied on the tractor when new. The L345 was offered with the US made 1720 loader. The number was the load rating in pounds - the kilogram rating would have been around 780. The 1720's main drawback is that its not easy to take off/ put back for mowing.
The LA450 I put on my L345 is on the small side for it - If I were outfitting a L345 with a non-original loader today, I'd look for a LA650 loader from a L3250, L3450, L3650 tractor.
/ KUBOTA LOADER #7
If you don't need a removable loader and want to go original, there's a rare used 1720 here in Oregon for $2k. Looks like the type that has a front pump & tank for the loader. The under frame on these is large with lots of bits & pieces, bolts, etc. Buying from a distance, ask seller to make sure its all included.
