Kubota load sensing pump system
/ Kubota load sensing pump system #1
Hersheyfarm
NE ky
Kubota lists their pumps as load sensing. Is this a piston pump with an adjustable swash plate?
/ Kubota load sensing pump system #2
Typically yes load sense is a variable volume piston pump.
/ Kubota load sensing pump system #3
Yes usually a axial piston pump with a swash plate that is constantly being adjusted to meet flow and pressure requirements. On a lot of the compact excavators it will have two outlets and some manufacturers count it as 2 pumps even though its just one rotating group of pistons in one cylinder. Then they piggy back a gear pump to it and call it a three pump system or a 4 pump system if there also counting the little pilot pump.
So the swash plate is moved back and forth by something monitoring flow or pressure, or both.
/ Kubota load sensing pump system #5
A load sense pump has a pilot line on the control that is used to sense pressure Down stream of a control valve . The pump produces flow to keep a constant pressure drop across this valve. If only one function on the valve is in operation it provides a constant flow independent of load changes. This provides a more consistent movement speed of functions.
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2001 Wellcraft Boat w/ 2000 Boat Trailer, (A61574)
2001 Wellcraft...
2360 (A64281)
2360 (A64281)
EZ Trail 3400 (A63688)
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
