Kubota load sensing pump system
   / Kubota load sensing pump system #1
Hersheyfarm
Veteran Member
NE ky
Kubota lists their pumps as load sensing. Is this a piston pump with an adjustable swash plate?
   / Kubota load sensing pump system #2
Typically yes load sense is a variable volume piston pump.
   / Kubota load sensing pump system #3
Yes usually a axial piston pump with a swash plate that is constantly being adjusted to meet flow and pressure requirements. On a lot of the compact excavators it will have two outlets and some manufacturers count it as 2 pumps even though its just one rotating group of pistons in one cylinder. Then they piggy back a gear pump to it and call it a three pump system or a 4 pump system if there also counting the little pilot pump.
So the swash plate is moved back and forth by something monitoring flow or pressure, or both.
   / Kubota load sensing pump system #5
A load sense pump has a pilot line on the control that is used to sense pressure Down stream of a control valve . The pump produces flow to keep a constant pressure drop across this valve. If only one function on the valve is in operation it provides a constant flow independent of load changes. This provides a more consistent movement speed of functions.
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
Caterpillar Loader Quick Coupler (A53472)
Caterpillar Loader...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
