Kubota leaks again !
   / Kubota leaks again ! #1
Bigbear4x4
Frenchville, Maine, U.S.A.
John Deere 4115
Hi , I have a 2006 BX1500 with an axle , center bolt leak, again ! I have changed the o rings several times. I now have about 740 hours so I'm quite sure I should be changing the center bolt, bushings, nylon washers and o rings but was wondering what others think about replacing the 85-90 w gear oil with a 200 w gear oil or thicker , just Not grease !. Tractor sleeps in a heated garage. The FEL is always on summer & winter with a rear snowblower. Advise would be appreciated .. Thanks for your time. Dana Anderson, northern Maine:confused:
   / Kubota leaks again ! #2
I would be cautious about using to thick of fluid since it might not lubricate / flow properly in the winter. I suspect that 85W-140 would work though.
   / Kubota leaks again ! #4
The fill plug on my Kubota front axle has a "vent system" built into the plug. I clean the plug/venting system every time I check the oil. Its never been plugged but I don't need problems there.
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
1995 PETERBILT 377 TRI  AXLE DUMP TRUCK (A54607)
1995 PETERBILT 377...
