Kubota leaks again !
   / Kubota leaks again ! #1
Bigbear4x4
Frenchville, Maine, U.S.A.
John Deere 4115
Hi , I have a 2006 BX1500 with an axle , center bolt leak, again ! I have changed the o rings several times. I now have about 740 hours so I'm quite sure I should be changing the center bolt, bushings, nylon washers and o rings but was wondering what others think about replacing the 85-90 w gear oil with a 200 w gear oil or thicker , just Not grease !. Tractor sleeps in a heated garage. The FEL is always on summer & winter with a rear snowblower. Advise would be appreciated .. Thanks for your time. Dana Anderson, northern Maine:confused:
   / Kubota leaks again ! #2
I would be cautious about using to thick of fluid since it might not lubricate / flow properly in the winter. I suspect that 85W-140 would work though.
   / Kubota leaks again ! #4
The fill plug on my Kubota front axle has a "vent system" built into the plug. I clean the plug/venting system every time I check the oil. Its never been plugged but I don't need problems there.
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
CAT 973 (A47384)
CAT 973 (A47384)
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2018 CATERPILLAR 815K LANDFILL COMPACTOR (A52705)
2018 CATERPILLAR...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
