Kubota leaks again !
   / Kubota leaks again ! #1
Bigbear4x4
Frenchville, Maine, U.S.A.
John Deere 4115
Hi , I have a 2006 BX1500 with an axle , center bolt leak, again ! I have changed the o rings several times. I now have about 740 hours so I'm quite sure I should be changing the center bolt, bushings, nylon washers and o rings but was wondering what others think about replacing the 85-90 w gear oil with a 200 w gear oil or thicker , just Not grease !. Tractor sleeps in a heated garage. The FEL is always on summer & winter with a rear snowblower. Advise would be appreciated .. Thanks for your time. Dana Anderson, northern Maine:confused:
   / Kubota leaks again ! #2
I would be cautious about using to thick of fluid since it might not lubricate / flow properly in the winter. I suspect that 85W-140 would work though.
   / Kubota leaks again ! #4
The fill plug on my Kubota front axle has a "vent system" built into the plug. I clean the plug/venting system every time I check the oil. Its never been plugged but I don't need problems there.
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2017 CATERPILLAR D11T DOZER (A52705)
2017 CATERPILLAR...
2020 FREIGHTLINER DEBRIS BUCKET TRUCK (A51406)
2020 FREIGHTLINER...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
377811 (A48836)
377811 (A48836)
