Kubota LA351 valve block
   / Kubota LA351 valve block #1
Iron Brew
Vancouver Island
Kubota b2400 SOLD. Now a Massey Ferguson 285 SOLD. Now a Kubota 50HP
I have an LA351 Kubota loader. I took the valve body off today, with the intention of replacing the o-rings (or whatever). No problem, I figured... pull it off, read the manufacturer name on the casting, and the model number, and get parts... Great...
Till... I tried to get a name... I have nothing. Anybody able to point me in the right direction? Yes, I went to the Kubota dealer, and while they
The other thing I'd like to know is the flow rates... What comes into the valves, and how much of that goes through the power beyond? As I plan on putting another valve block on for a grapple, I figure I may just add some rear hydraulics at the same time, using the power beyond.
Thanks
   / Kubota LA351 valve block #2
Kubota B2400
Hydraulics:
Type: open
Capacity: 3.2 gal [12.1 L]
Pump flow: 5.8 gpm [22.0
Same pump fluid flows through all valves at 5.8 GPM.
So your new valve should be able to handle at least 5.8 GPM.
Thanks JJ.
Any idea what that valve block would be (ie make? there are numbers that would probably let me find the model)? I want to rebuild it and need to go to the local hydraulics supply for rings... (before I open it)
Thanks
   / Kubota LA351 valve block #4
Is there a name plate that has been painted over? Some OEM's paint everything and this can make the name plates blend in with the castings, etc..
All else fails take the valve bank with you to the hydraulic shop and they can probably size the O-rings while you wait.
Roy
   / Kubota LA351 valve block #5
See if this well help.
  • LA351.pdf
Roy
Nope, found all sorts of casting numbers etc. but not a brand name. I'll take it into the city with me today and see if I can get some proper sized rings.
Well, pulled apart my valve... the detents are pretty eukered. On one, the ball bearings were worn down, and there was damage in that spool area. Plastic spacer had damage. Cleaned it up and re-installed. I guess I need to start watching for sales for a good loader valve without plastic bits...
Found this one
Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
Any recommendations on brands? As I say, not a rush at the moment, one to keep an eye on sales for...
Thanks
   / Kubota LA351 valve block #9
Found this one
Thanks
That joystick valve should work fine, and here is a selector/diverter valve for the grapple.
Surplus Center - SAE 8 15 GPM DOUBLE SELECTOR VALVE 12 VDC P15544-1
   / Kubota LA351 valve block #10
i have a similar problem. i thought i finally got the @(&%!%& thing fixed, new o-rings, cut (and ground flat) some pvc tube to replace the busted up plastic bits, made some gaskets.... got it all back together no leaks:thumbsup: so i reconnected the loader, and oil everywhere:mad: i'm thinking the thing is toast and i don't want to deal with it anymore. at least until i saw the price of the replacement !!!!$$$$$!!!!! that's insane.
so my question: i looked at the link above, and it looks like it accepts 2 hoses from the tractor and 4 out to the loader. my valve has 3 from the tractor and 4 out to the loader. what's the 3rd one (the one on top i'm guessing) do? what do i do with it if i replace the control valve with one of these non kubota valves. or better yet can someone point me in the direction of a better replacement (one with 3 from the tractor and 4 to the loader - with float please :D)
thanks,
neil
2011 MACK PINNACLE (A58214)
2011 MACK PINNACLE...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2015 GENIE Z-62/40 TELESCOPIC/SCISSORING BOOM LIFT (A52709)
2015 GENIE Z-62/40...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
Zero Turn Mower (A55853)
Zero Turn Mower...
