kubota LA351 loader -- how to quick-disconnect -- ??
/ kubota LA351 loader -- how to quick-disconnect -- ?? #1
Unregistered2013
not to sound too noob here, but i was looking at my loader on my B2400, and cannot firgure how to quick-disconnect it --
-- any input would be welcomed --
THANK YOU!
eric
/ kubota LA351 loader -- how to quick-disconnect -- ?? #3
I'm not sure if the loader you have is like the later LA352, or not. The process that I learned is to raise the loader high enough to install/lower the loader support stands, and do that. Then tilt the bucket down 15-20 degrees, and put enough down pressure against the ground to relieve the pressure on the loader pins at the top of the rear loader frame. Remove those two pins ( one on each side). Curl the bucket back towards horizontal, and as you do that, the loader will rise out of the rear masts. When the loader is clear of the masts, you can back up just a few inches, shut the tractor off, and cycle the joystick through it's full range of motions. Set the brake, dismount the tractor, and disconnect the hydraulic lines. On some tractors, some of those lines have to be reconnected to the tractor (older BX series) but I don't think that is true on yours. Hopefully, this is enough information to help you out. Look carefully at your loader, and I think you will find enough things that look like what I described to get you started.
Good luck ...
thank you for this, kind sir!
:D
i will give it a look tonight!
Good luck ...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
2007 Ford Fusion Sedan (A64557)
2007 Ford Fusion...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2014 Dodge Caravan Van (A64557)
2014 Dodge Caravan...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
