Kubota la1150 loader support brackets, how to use
   / Kubota la1150 loader support brackets, how to use #1
Walkintall9000
Kubota L5450
There are two brackets across the front of my loader and I assume they are support brackets to hold the loader up when working on the tractor, but I don't know how to use them or where they go. Any help would be appreciated. Thanks!
   / Kubota la1150 loader support brackets, how to use #2
I believe the brackets you are referring to are used to support the loader arms when removing the fel from the tractor.
They could be, they go from one side to the other and are attached to two pins. But I don't have any idea how to use them or how they attach. Lol. Thanks for your help!
That is a pic of the arms I am talking about!
Maybe if anyone had a pic of them in use I could see how they attach. Thanks for the help!
   / Kubota la1150 loader support brackets, how to use #6
You have an owners manual? It will explain the attachment points.
   / Kubota la1150 loader support brackets, how to use #7
I haven't seen a setup like that. My previous L3410 had a bolted on crossover brace in the same location, and drop down bars on the loader arms to support the fel when removing from the tractor. Maybe look for some unused pins on the loader arms that match up to the holes in those brackets.
Hopefully someone with a similar loader will chime in.
John Deere 6125R (A60462)
John Deere 6125R...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
