Loader Kubota LA 900 Loader cyllinder
   / Kubota LA 900 Loader cyllinder
Thank you all for your input.
I think I have it solved.
The Kubota cylinders are 60MM. 2 3/8"" ROUGHLY. they use a 30mm pin, and have a 20.1'' stroke. collapsed are 30''
I found a pair of 2 1/4' cylinders. they have about 10% less surface area than the 60mm. with the needed length 30'' and 19 1/2 stroke (1/2"" short using a 1 1/4'' pin.
I can bush to 1 1/4'' down to 30mm and use the kubota loader pins.
Its an occasional use loader with a clam shell bucket
Is there a shortcoming to this plan?
The pair of replacement cylinders will be under $400.
   / Kubota LA 900 Loader cyllinder #12
That sounds like the best solution to me-it should work very well.
   / Kubota LA 900 Loader cyllinder #14
Have you checked your loader spec against your machine type? An LA 900 would lift over 2000 lbs. This is probably well over the safe handling capacity of your machine, even with over ballasting it.
LA 900 loaders came on L3750mf (my tractor) according to Kubotas' website.
I will change to r 4 tires and rims in front.
The 3750 and 4150 are cousins and share engines, transmissions, differentials and major housings according to the Kubota wsm and parts manuals.
The loader manual is part of the WSM
Yard Machines Tiller (A55973)
Yard Machines...
Informational Lot - Shipping (A56435)
Informational Lot...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
More info coming soon! (A56858)
More info coming...
2016 Ford Escape SUV (A56859)
2016 Ford Escape...
