Kubota L6060 Engine failure
   / Kubota L6060 Engine failure #141
Sorry to hear this outcome. Particularly for your sake and also for other Kubota owners out there. Including me with pretty much the same model.
   / Kubota L6060 Engine failure #142
Oof, that blows. C'mon Kubota.
I would love if we had a fuel-injector engineer on here to chime in. I am still confused how any commanded duty cycle or rail pressures would wipe out the fuel pump and injectors all at one time. Still kinda smells like the shop just threw all the parts at it to get it running.
   / Kubota L6060 Engine failure #143
Thanks for sharing a painful experience. A few of those repairs would end my hobby farming. Beginning to talk like my dad on the “economics” of new equipment.
Hope for trouble free hours from now on.
   / Kubota L6060 Engine failure #144
I have had many helpful comments from people on this site. Thank you all. Here is the latest information. The fuel tests came back clean. The injector tests came back with all four injectors "stuck closed". The solenoid controlling the injector pump tested as working properly. However, the pump was producing no output. It had failed. Finally, it was discovered that the ECU had failed. All three failed simultaneously. Neither the dealership nor Kubota can give me any explanation as to how or why this could happen. The only explanation that I have heard that made any sense was that the ECU failed in a catastrophic way that took out the pump and injectors with it. The ECU is the only common denominator in this failure. i controls the flow of fuel to the pump, the pressure in the rail by modulating the injector pump solenoid, and controls the timing and opening and closing of the injectors.
Kubota has decided not to assume any responsibility for this failure.
For those of you that own a L6060, I hope for your sake that this was a fluke occurrence and it won't happen to you. Imagine the damage that could occur if the ECU decided to fail in a way that opened an injector when a piston was in the wrong position.
For those of you considering buying an L6060, be warned. This was a $10,027.09 bad experience for me.
This is a very unfortunate outcome. I am very sorry.
I feel that Kubota should have assumed "some" responsibility for the failure.
This outcome will be factored in my future purchase decisions and perhaps alternative brands will become more attractive down the road.
Mike
   / Kubota L6060 Engine failure #145
I would take the injectors and pump to a place that specializes in fuel injectors. I realize your location might make that tough but with all the trucks around there, there must be a place. See if they can do a post mortem to tell you what they think happened.
   / Kubota L6060 Engine failure #146
Too bad Kubota kept the parts......isn't it? No evidence, no lawsuit.
   / Kubota L6060 Engine failure #147
I imagine AK could request those parts returned to him.
Kubota shouldn't keep those parts...they didn't pay for them!
Mike
   / Kubota L6060 Engine failure #149
That's a terrible outcome and I hate to hear anyone go through this.
I believe I would be trading into another brand . If you take away reliability there's nothing special about a kubota compared to other top tier brands.
I believe I will for sure be trading out of my brand new grand L4060 just as soon as I can . I understand failures happen but I totally think the dealer was incompetent and kubota could've stepped up and offered something I mean come on. That's bs .
   / Kubota L6060 Engine failure #150
Selling a brand new tractor in AL because of an incompetent dealer in AK. That'll show 'em!
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
