Kubota L5030HSTC A/C Not Cooling Properly
   / Kubota L5030HSTC A/C Not Cooling Properly #1
jrepp
North West Louisiana
Kubota L5030HSTC
Does anyone have any tips on how to increase the A/C cooling? I have cleaned all of the cooling fins and screens. Do the freon kits they sell at Wally-World and elsewhere to add freon do any good? There is a site glass near the front of the engine, should I see bubbles or not? Thanks Jim.
   / Kubota L5030HSTC A/C Not Cooling Properly #3
Jrepp, check out this thread on the topic... here .
I have a 5030 HSTC and see no bubbles in the sight glass. The manual says that either there is too much coolant or it is out... that there should be a few bubbles going by. My AC works but is weak, have not had a chance to take to the dealer for evaluation. I plan to install the bubble insulation as discussed in the thread above. I jump in and out of the tractor often, thus loosing all cooler air frequently, so it could by my useage habits that make it seem weak.
   / Kubota L5030HSTC A/C Not Cooling Properly #4
   / Kubota L5030HSTC A/C Not Cooling Properly #5
Have you checked the air conditioning belt for proper fit? This has happened to my even with checking the belt on the checkups as noted in the manual.
   / Kubota L5030HSTC A/C Not Cooling Properly #6
DumbDog,
By fit do you mean tension? If not, could you explain what I should look for. Thanks, Jim (jrepp).
DumbDog,
   / Kubota L5030HSTC A/C Not Cooling Properly #9
I should have said tension, every time my 4630 does not cool properly that has been the problem except for the other day when I moved the temperature lever instead of the control lever. The heater does work when it is 90 degrees outside.
   / Kubota L5030HSTC A/C Not Cooling Properly #10
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
