cardiofuse
- Joined
- Nov 29, 2023
- Messages
- 11
- Tractor
- KUBOTA L48
I would like to replace the glow plug relay and controller behind the dash but have no idea how to remove the dash. Can anyone help with this? 2002 L48
Is the center screw you’re referring to attaching the center of the plastic dash panel; like underneath?Check Messicks here for tips on the glow plug relay replacement Kubota #16415-65600 RELAY, GLOW PLUG
Installation Tips
Unrated (50 minutes)
After removing all the bolts and screws from the dash, don’t forget one bolt in center of housing next to fire wall and unscrew the tachometer. The dash can be moved enough to get to the parts
Not sure. The quoted installation tip is pretty generic and may not be for your machine since the glow plug relay for your machine is used in over 60 different machines.Is the center screw you’re referring to attaching the center of the plastic dash panel; like underneath?
Should I also be checking for a timer module or a thermistor (not sure where the temp probe is; although the dash temp gauge works fine?Chewwy - This is the instruction for the L48 relay replacement.
Here is the link to Messicks for the dash panel Kubota L48 Parts Diagrams
Here is another view of the relay location. Kubota L48 Parts Diagrams
