Oil & Fuel Kubota L48 cranks but will not start
   / Kubota L48 cranks but will not start #1
Suzi
NH, MA
Kubota L48
My Kubota started fine this morning, but then it stalled out. It is turning over, but will not start. It has plenty of diesel. The fuel does not seem to be flowing past the injection pump. Any suggestions? Trying to trouble shoot. Thank you for your assistance!
Suzi
   / Kubota L48 cranks but will not start #2
check that the fuel shut off solenoid is operating correctly. If the solenoid is bad and wont open then fuel wont flow. That would be the first thing that I would check.
   / Kubota L48 cranks but will not start #3
Suzi
Agree with treeeman. I believe the fuel shut off solenoid is fused. Start by checking the fuse.
   / Kubota L48 cranks but will not start #4
Stalling after running could be a plugged fuel filter. Or skudge in the tank blocking the outlet. Can you see if the filter bowl is full?
Depending on whether your L48 is the newer or older style (SN up to 52526 or 52527 & above) the fuel solenoid system is different. I think on the earlier one its only active to stop the engine. Later it was changed to be active to start too.
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
True 750E Elliptical (A54816)
True 750E...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2005 MERCURY Grand Marquis (A56859)
2005 MERCURY Grand...
John Deere 5055E (A53317)
John Deere 5055E...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
