Oil & Fuel Kubota L48 cranks but will not start
   / Kubota L48 cranks but will not start #1
Suzi
NH, MA
Kubota L48
My Kubota started fine this morning, but then it stalled out. It is turning over, but will not start. It has plenty of diesel. The fuel does not seem to be flowing past the injection pump. Any suggestions? Trying to trouble shoot. Thank you for your assistance!
Suzi
   / Kubota L48 cranks but will not start #2
check that the fuel shut off solenoid is operating correctly. If the solenoid is bad and wont open then fuel wont flow. That would be the first thing that I would check.
   / Kubota L48 cranks but will not start #3
Suzi
Agree with treeeman. I believe the fuel shut off solenoid is fused. Start by checking the fuse.
   / Kubota L48 cranks but will not start #4
Stalling after running could be a plugged fuel filter. Or skudge in the tank blocking the outlet. Can you see if the filter bowl is full?
Depending on whether your L48 is the newer or older style (SN up to 52526 or 52527 & above) the fuel solenoid system is different. I think on the earlier one its only active to stop the engine. Later it was changed to be active to start too.
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
PT 7' x 12' 4 Wheel Wagon Frame (A53317)
PT 7' x 12' 4...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A55852)
1989 AM General...
2012 International 4300 Reefer Truck (A56435)
2012 International...
(18) 2" X 6" X 29" TUBING (A57192)
(18) 2" X 6" X 29"...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
