Kubota L4760 with Sbp1684 snowblower??
   / Kubota L4760 with Sbp1684 snowblower?? #21
You're going to love having a rear pull snowblower. It's perfect for your long drives. I think 84" will be okay most of the time. If you get heavy/deep snow, you may have top go a little slow on your first pass. On subsequent passes, you can take a partial width if necessary. I have a M K Martin 68" rear pull, and I love it. I had a conventional 3pt snowblower before that, and I can do the same work in 1/2 the time.
Here it is in action.
   / Kubota L4760 with Sbp1684 snowblower?? #22
TractorTYMe is a TNBn member and loves his also. He has posted a few vids
I would be willing to bet that the vibration is from the 2 different angles on the pto shaft's U-joints when it's raised up. Either live with it, or get a CV (Constant Velocity) jointed pto shaft with the CV joint put at the tractor end. Your tractor's transmission will appreciate the investment .
Where would one get one of these atatchments? I’ll try lowering the blower closer to the ground and running it to see if the shake goes away. I was freaking out thinking my 11k dollar snowblower was a lemon!
The whole blower looks like it’s rocking side to side when it’s running. But I’ll check in the am
   / Kubota L4760 with Sbp1684 snowblower?? #25
It's important that PTOs are in phase. Most modern PTO shafts can only go together one way. Extreme angle can also cause vibration. You may have different vertically spaced holes for your 3pt connections. The closer to parallel, the happier everything is. Finally be sure your PTO shaft isn't so long that it bottoms our ti the (extreme) raised position.
   / Kubota L4760 with Sbp1684 snowblower?? #26
Got the blower hitched up and mounted. Turned it on and spun it up. There’s a decent shake to it when it’s off the ground running at rpm. Is that normal?
The shake is due to the impeller not being balanced on a high speed balancer
and having weights welded to the impeller paddle sleeve weldment to counteract
the imbalance created by the centrifugal force created by spinning the impeller.
I had the same issues with the 42 inch snow blower on my john deere lawn tractor.
Is there a way to fix this?
The whole tractor rocks side to side when things going anytime I lift it off the ground. It’s seriously annoying.
   / Kubota L4760 with Sbp1684 snowblower?? #29
I suspect the blower will settle down while blowing snow, but your description sounds more on the severe side. My blower will shake slightly when raised or when first powered up, but it doesn't shake the tractor to any noticable extent.
I think you should have the selling dealer look at it.
   / Kubota L4760 with Sbp1684 snowblower?? #30
Are the lower links tightened up to prevent swaying???
Start with the gear box and check to assure the hold down bolts are tight; if not, they need
to be torqued to the proper tension after the application of blue loctite.
Check the open bearing housing in the rear of the snow blower that supports the impeller
shaft to make sure it is also tightened on the inner race of the bearing as well.
Last but not least is impeller for balancing.
One of the other members had a bushel of trouble with his rear pull snow blower and
they replaced it if I remember what happened correctly.
Before you do anything have the dealer pick it up to cover your end of things as it is VERY,
VERY, VERY, likely it is a problem with the snowblower NOT YOU. BE SURE TO TAKE A VIDEO OF THE SHAKE
RATTLE AND ROLL to cover yourself AS THE SNOW BLOWER SHOULD NOT DO THIS.
The thing is the PTO connection from the mule to the snow blower is a linear connection to the implement with
universal joints that are 90 degrees opposed and operate correctly as long as the PTO shaft inner and outer sleeves
are cut to the proper length to prevent the possibility of breaking the gearbox of the snow blower and breaking
the very expensive male PTO shaft housing and bearings in your mules final drive train to the power take off shaft.
I would ask for a refund of your money and order a Pronovost rear pull snow blower if you really have to have one.
They will try to accuse you of having buyers remorse; do not fall into that trap and ask for a refund of your money
as the machine should not be swaying like this if the unit was properly balanced.
202477 (A54757)
202477 (A54757)
New/Unused AGT Industrial Bucket Mixer (A57454)
New/Unused AGT...
14 Gun Fireproof Safe (New/Unused) (A59225)
14 Gun Fireproof...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
Yukon Jack Skid Steer Bucket Attachment, 46" W x 48" L, Asset# 70 (DELAYED REMOVAL, CONTACT SITE (A59076)
Yukon Jack Skid...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
