Oil & Fuel Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start...
   / Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start... #31
“Just LOOSEN the lines AT THE INJECTORS a couple of turns.. and crank the engine until fuel squirts out and tighten.. start engine”
It doesn’t always work. I just had to get my deutz running from being out of fuel.
despite injection bleed and plenty of flow, no go
Had (someone who knows what they are doing) feather a bit of ether in the air intake 5sec of crank and bingo. This was after someone killed a battery and jump pack from trying.
I had flow through lift/separator/filter/hp pump and injection lines. Only injectors and intake were left
got it started
good video on the topic for Kubotas... it doesn't have the bleeder valve so it must be a bit older yet than 2013 but gives good visuals on the guidance provided by forum members above (minus the fact that they do mention up front not removing the injector feed pipes at the pump side but then they show removing and reconnecting the injector feed pipes at the pump side! avert your eyes @pumpguysc! ) :
In the meantime, I ordered this for my Kubota's key chain.
   / Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start... #33
Glad to learn she is running for you!
   / Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start... #34
On most diesels I will crack open all the lines at the injectors OPEN THROTTLE and crank till I see fuel coming out of the injector line. I like to close them while this is happening (sometimes it will start then) then close them all up and start it (here goes the haters) then a light spray of either. Your tractor though, do as you see fit.
Doing 1 at a time is better. Start with the first line off of the pump. Should start if not. Then when you spray either in air filter have some one crank the engine over. Should have 2 people to do this. Spraying either in while NOT turning engine over can damage the engine. Good luck
   / Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start... #35
Being in the timber business, two things I never allow to run out of diesel, a tractor or a fork lift, either can be a real nightmare to get restarted in the field.
I try to never allow a tractor to go below a quarter tank.
In another thread someone expressed concern that this could lead to one of the cylinders not firing because it doesn't get fuel (et al. that injector doesn't ever get fuel if air is trapped between sender and injector)-- thus damaging that cylinder... Is that an old timer diesel issue or ... a non-Kubota issue?
   / Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start... #37
Do not use ether on a Kubota!
Do not burn up the starter.
Clean up your tractor's spilled diesel - before running enough to warm up the exhaust manifold.
Have a fire extinguisher handy when you warm it up the 1st time.....
   / Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start... #38
Geeeeezzzzzzeee Louise!
When you are too close to being out of fuel and it starts to die. Shut it off. Put sufficient fuel into the tank and loosen at least one INJECTOR line at the INJECTOR if it will not start. Pumps do not handle air so by loosening at least one line it allows the air to escape so fuel can follow. Crank it til it starts to fire and then tighten the line(s). Done.
Mine (2013 L4600H ) has a bleeder valve below the senders in the fuel pump but this did nothing to help. I don't know if it was the fact that it stalled on a downhill slope (probably why I had near zero warning... every last sip of diesel was sent down to the fuel filter on that last pass downhill) and so the bleeder didn't help in this particular situation or.. the bleeder is of no use on this model.
Maybe loosening one injector had the desired effect. I saw no fuel coming out of the fuel line after loosening the line to the injector closest to the steering wheel. After a lot of cranking, hoping that would push fuel out of that first line, I gave up and put the line back on. Tried it again with the bleeder open and then with it closed and then open again and closed again. On the last "closed again"... after a few more cranks it caught on at very low revs for about 20 seconds and then slowly built up to full power.
That's why I posted the question about possibly fuel-starving one cylinder with this method... if you don't loosen every line and see fuel coming from every line... is that a bad approach?
   / Kubota L4600 ran it out of diesel, emptied fuel filter bowl... won't start... #40
A faster easier solution is to spray WD-40 into the air intake, The engine will run on the WD-40 until it picks up the fuel. As stated earlier DO NOT use ether.
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
