Comparison Kubota L4600 and John Deere 5045D
   / Kubota L4600 and John Deere 5045D #11
I was thinking maybe a Kubota mx4700/5100,4x4 but wasnt gonna say it or the L4600 4x4... But out of the two in 2wd I would get the DEERE and thats coming from a Kubota GUY:D
Yeah, but I'd rather have an orange 4wd tractor...:D
   / Kubota L4600 and John Deere 5045D #12
Don't recall seeing a loader being added, but certainly agree with 4wd when adding loader. I have been down the 2wd loader road. It is better than not having loader at all, but doesn't compare to same setup with 4wd. Certainly worth considering if budget allows.
   / Kubota L4600 and John Deere 5045D #13
I readily admit to not being well versed in Kubota models but I am familiar with most of the Deere stuff. That said I think a smaller 3x20 or 4x20 series Deere or similar tractor from other brands should be a better suited for the OP's tasks. Most of this mowing, grooming and snow removal is what I consider light work and would benefit more from having a smaller hydro tractor instead of a larger gear tractor.
   / Kubota L4600 and John Deere 5045D #14
I would agree. After considering that some users may not be comfortable operating a tractor in the first place and may not be familiar with gear selection/changing, the hydro would likely be MUCH easier to use and thereby safer too.
   / Kubota L4600 and John Deere 5045D #15
Looking at your list of tasks I don't see the need or benefit in a larger frame tractor, it would seem that a compact utility should be a good fit.
By suggesting a smaller tractor, You have gone against every TBN code of honor ever made! :laughing:
Just kidding, I agree that the compact would be well up to the tasks. HST is a godsend.
   / Kubota L4600 and John Deere 5045D #16
All three mentioned have HST,then there is the GrandL's:D
I gave it to the deere out of the two,but if were going to get into other numbers,gonna stay on the orange side of fence;)
CFG Industrial 12EX-ATA Mini Excavator Attachment Set (A57149)
CFG Industrial...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
Billy Goat Walk Behind Sod Cutter (A57149)
Billy Goat Walk...
2022 FORD F-250 (A58214)
2022 FORD F-250...
2018 John Deere TX (A53317)
2018 John Deere TX...
