Kubota L4310 gear teeth in hydraulic filter?
   / Kubota L4310 gear teeth in hydraulic filter? #11
To me, that looks more like splines rather than gear teeth. Looking at how the material looks and broke, makes me think it's cast iron.
At first, I was thinking diff lock, but checking the parts catalog and some pictures of the actual parts and it doesn't even have splines there.
I've got a 3130 all the splines sheared off . Replaced under warranty...... known problem some shafts weren't hardened they said. Same vintage.
   / Kubota L4310 gear teeth in hydraulic filter? #12
Those are very small teeth. Too small for pump teeth. They almost look like flywheel teeth but I don't know how they'd get into the trans oil. The gear they come off of would be fairly small but large in diameter. It's almost like someone may have placed them there on purpose. :poop:
   / Kubota L4310 gear teeth in hydraulic filter? #13
I figured it was splines. The shape, profile and machining marks gave it away.
What did this issue affect function wise on your tractor?
   / Kubota L4310 gear teeth in hydraulic filter? #15
Finally nothing won't move. Shaft was just spinning.
   / Kubota L4310 gear teeth in hydraulic filter? #16
Possibly left over debris from a previous repair? Can you tell if the tractor was ever split?
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
HYSTER H55VM...
