Kubota L4310 gear teeth in hydraulic filter?
   / Kubota L4310 gear teeth in hydraulic filter? #11
To me, that looks more like splines rather than gear teeth. Looking at how the material looks and broke, makes me think it's cast iron.
At first, I was thinking diff lock, but checking the parts catalog and some pictures of the actual parts and it doesn't even have splines there.
I've got a 3130 all the splines sheared off . Replaced under warranty...... known problem some shafts weren't hardened they said. Same vintage.
   / Kubota L4310 gear teeth in hydraulic filter? #12
Those are very small teeth. Too small for pump teeth. They almost look like flywheel teeth but I don't know how they'd get into the trans oil. The gear they come off of would be fairly small but large in diameter. It's almost like someone may have placed them there on purpose. :poop:
   / Kubota L4310 gear teeth in hydraulic filter? #13
I figured it was splines. The shape, profile and machining marks gave it away.
What did this issue affect function wise on your tractor?
   / Kubota L4310 gear teeth in hydraulic filter? #15
Finally nothing won't move. Shaft was just spinning.
   / Kubota L4310 gear teeth in hydraulic filter? #16
Possibly left over debris from a previous repair? Can you tell if the tractor was ever split?
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2015 INTERNATIONAL DURASTAR 4400 WATER TRUCK (A53843)
2015 INTERNATIONAL...
2022 ALLIANCE NORTH AMERICA, INC SDG45 GENERATOR (A53843)
2022 ALLIANCE...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
