Kubota L4240 Factory 3rd function Kit
   / Kubota L4240 Factory 3rd function Kit #11
The white button turns the two joystick buttons (and the front hydraulics) on and off. The box on the side is for the valve. Metal lines run to the front of the loader where the disconnects are located. I have this setup on my tractor and its nice (but expensive).
Make sure the joystick is adjusted so that the seat can flip up without hitting the joystick. Mine was turned in too far and it was hard to flip the seat up to run the pto without moving the FEL. Its a quick fix with a 19 mm wrench.
I purchased my L4240 Jan.2008,had the third function installed Sept.2008
valve........$779.00
labor........$242.28
pick-up.....$125.00
total...$1146.28
I guess things have gone up!
I like my dealer..he has been more than fair;I have purchased two tractors and $5,000 worth of implements from him.
Dan, looks like an across the board hike. Also looks like your dealer likes you!
Thanks for posting the pricing info. I think this is a sign of where things are headed :(
   / Kubota L4240 Factory 3rd function Kit #13
Here's the Kubota 3rd function valve & connections on my L4240. The dealer installed it before delivery last year. It works great, no problems so far.
I have the same setup on my 3940. Shopping grapples at the moment and looking forward to trying it out.
Big Al
   / Kubota L4240 Factory 3rd function Kit #14
I like the Kubota steel lines on the FEL. Is it just a kit that comes with all the parts or do they break down on the parts needed? I would love to see a list of all the parts.
   / Kubota L4240 Factory 3rd function Kit #15
I looked at my installation manual for the third function....I would bet that it comes in kit form.Being an old retired pipefitter that has done some tube bending;I wouldn't think they would expect every tractor mechanic to be proficient in tube bending.It is quite a process,the rear tire has to be removed and the FEL supports(on one side),about six hours labor.
   / Kubota L4240 Factory 3rd function Kit #16
What's the white button on the lever? I thought someone had said it was a second valve. Is that box with the "no step" on the side of your tractor for the quick disconnects?
I think JimP answered but there is also another pair of disconnects over the FEL disconnects to allow loader removal. They are the top ones with the white dust caps.
   / Kubota L4240 Factory 3rd function Kit #17
I can attest to the amount of work that's necessary. I bought the kit for $818 plus $35 shipping. In order to do the install on my L5240, I had to do the following (most of which was outlined in the Kubota instructions):
1. Remove the loader and hydraulic fluid.
2. Remove the loader mainframe on the right side. I did not have to remove the subframe as the instructions indicated.
3. Remove the right rear fender. I did not have to remove the rear wheel as the instructions indicated. This may have been because my wheels are set wide.
4. Remove right steering linkage.
5. Remove right brake lever.
6. Remove two steel hydraulic lines. One of these - referred to as the third inlet tube - was tough to get out. You can cut it out, but I found after some time that the trick is to have someone step on the brake to make just enough room to slip it out.
7. Install a couple of tubes and hoses - no bending necessary, but I had to remove the hydraulic fluid filter to get both hoses routed.
8. Install the hose coupler.
9. Put the mainframe back on and attach the valve/solenoid to it. Then, connect the valve/solenoid to the coupler.
10. Remove the old lever.
11. Install the new lever.
12. Hook up electrical connections. The pushbutton switch on my lever is bad (it was shipped broken), so I'm just replacing the switch, rather than the whole lever.
13. Install tubes on loader boom.
This project was a collossal pain in the grass, but at the end of the day, a good experience for a novice tractor owner. I'd do it again.
   / Kubota L4240 Factory 3rd function Kit #18
he stated the obvious alternative,...add 2 hoses from rear port to set of quick connects on front of loader, and save about $900 off of combined totals.
Just think about using this option, having to go back and forth to clamp and curl....does not work, get the joystick electric remote it is worth it in what the tractor can do afterwards.
In this case I think I like the aftermarket W R Long valve is better than the Kubota, would be nice to use the Long valve and Kubota lines on the loader frame.
David Kb7uns
   / Kubota L4240 Factory 3rd function Kit #19
David Kb7uns
? im confused. i have it on mine, works sweet. no issues at all.
   / Kubota L4240 Factory 3rd function Kit #20
You have it on yours for what? You list everything you have, have sold and have ordered, what runs off of your rear remotes that you run lines to your loader bucket for?? To run a grapple or a 4 in 1 bucket I would not want to reach to a different location for closing or opening the implement. Joy stick is the only way to go for the front end.
MarkV
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
2018 Dodge Durango Multipurpose Vehicle (MPV), 175,918 Miles, Third-Row Seating (A56438)
2018 Dodge Durango...
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
ASSET DESCRIPTIONS & CONDITION (A59575)
ASSET DESCRIPTIONS...
