Kubota L4200GST tractor - question about the operation of the gearbox.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #1
licz3
Kubota L4200
I have a question for users of the Kubota tractor with GST gearbox.
I have never come across this kind of gearbox and have owned a Kubota L4200GST since November.
How should a tractor behave when, for example, I gather a bucket of soil - is it normal that in higher gears the tractor simply stops as if it would disengage the clutch? The engine does not choke, the wheels do not turn and the tractor simply stops. The same is true when, for example, I am plowing - if I do not downshift to 3 or lower, the tractor stops.
Is this all normal or maybe some problems with the gearbox?
   / Kubota L4200GST tractor - question about the operation of the gearbox. #2
Drop down to lower gear(s). Might aggravate you because you are working slower, but ahhhh.. steadier.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #3
Here is a good video that describes the GST. I like mine. There is a slight pause as you shift into a different gear. The pause is slightly longer if that gear change also involves a range change. If your pauses are longer than that, maybe you need a slight linkage adjustment.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #4
The BEST video I've seen regarding GST.
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
1974 Ford F600 Grain Truck (A56435)
1974 Ford F600...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
