Kubota L4200GST tractor - question about the operation of the gearbox.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #1
licz3
Kubota L4200
I have a question for users of the Kubota tractor with GST gearbox.
I have never come across this kind of gearbox and have owned a Kubota L4200GST since November.
How should a tractor behave when, for example, I gather a bucket of soil - is it normal that in higher gears the tractor simply stops as if it would disengage the clutch? The engine does not choke, the wheels do not turn and the tractor simply stops. The same is true when, for example, I am plowing - if I do not downshift to 3 or lower, the tractor stops.
Is this all normal or maybe some problems with the gearbox?
   / Kubota L4200GST tractor - question about the operation of the gearbox. #2
Drop down to lower gear(s). Might aggravate you because you are working slower, but ahhhh.. steadier.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #3
Here is a good video that describes the GST. I like mine. There is a slight pause as you shift into a different gear. The pause is slightly longer if that gear change also involves a range change. If your pauses are longer than that, maybe you need a slight linkage adjustment.
   / Kubota L4200GST tractor - question about the operation of the gearbox. #4
The BEST video I've seen regarding GST.
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
202477 (A54757)
202477 (A54757)
