kubota l4200 bucket
   / kubota l4200 bucket
Has anybody got a diagram for taking apart the spool?
   / kubota l4200 bucket #22
Luath, maybe to help you understand your tractor.
The "spools" are components inside the hydraulic valve. The valve (loader valve) is the part with the handles attached to loader brackets (usually the "towers").
The spools are moved forward and backward by the levers on your valve as you move them. One one end of the spools is a pin with the levers, on the other end are some seals, springs, small round balls to make the "detent" (for float) work. You can't see this end. This is the end that is effected by water that gets trapped in the housing.
You can google "two spool hydraulic valve' and get a picture of what it looks like. There is some variation in valves, but pretty much all operate the same.
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2464 (A60432)
2464 (A60432)
(2) UNUSED FUTURE LUXURY EQUIPMENT SEAT (A60432)
(2) UNUSED FUTURE...
2016 FORD FUSION SS (A60430)
2016 FORD FUSION...
2014 International Maxxforce DT (A53317)
2014 International...
2014 F-150 STX (A56438)
2014 F-150 STX...
