kubota l4200 bucket
   / kubota l4200 bucket #1
Luath
Canada
Kubota L4200
Hi guys,
Started up the tractor today and I was unable to tilt the bucket. Raise and lower was fine but when I tried to tilt the lever had no side to side movement, forward and back felt normal.
Advice please.
Luath
   / kubota l4200 bucket #2
Unhook the four QD's, clean and then reseat them. This solves 90% of the "my loader won't xxx" problems.
Ok unhooked all four QD's, cleaned with paper towels and reseated them. No leaks or other signs of problems. Still no tilt on the bucket but all the other hydraulic functions seem fine (used the rear mounted snow blower without incident) and the up /down for bucket fine. Still no side to side movement on the bucket control.
   / kubota l4200 bucket #4
Temp below freezing? The valve may have some water in it that freezes in the bottom, blocking movement - if you let the tractor idle a while the fluid circulates through open-center system, warming it up and thaws it out enough to move. Some people drill a small hole in the center of the bottom cap so it drains.
   / kubota l4200 bucket #5
In sure that rbargeron has described your problem exactly ... I see your in Canada and it is December... Ice in the control valve is very common... There are quite a few older posts on what to 'try' doing for a fix, all work or at least help the situation. If you find that this is indeed your problem be sure to post back, And if you come up with any new or novel ideas as how to 'cure' this do post them. KennyV
Where exactly is the control valve located? Would it be ok to apply gentle heat to it?
   / kubota l4200 bucket #7
The valve is inside the box the lever goes down into. It sticks out below the box - applying some heat is ok - just don't overdo it.
Hair drier worked a treat! Open topped machine, any ideas as to how to prevent recurrence of issue?
Another point, is it ok to leave the block heater on for long periods during frigid weather? (I'm from UK where minus double digit temperatures are virtually unheard of)
Many thanks for the insights and advice.
Luath.
2' Auger Extension (A50774)
2' Auger Extension...
Land Honor Tree Puller (A50515)
Land Honor Tree...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50322)
2015 Clarke Power...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
