kubota l4200 bucket
   / kubota l4200 bucket
Has anybody got a diagram for taking apart the spool?
   / kubota l4200 bucket #22
Luath, maybe to help you understand your tractor.
The "spools" are components inside the hydraulic valve. The valve (loader valve) is the part with the handles attached to loader brackets (usually the "towers").
The spools are moved forward and backward by the levers on your valve as you move them. One one end of the spools is a pin with the levers, on the other end are some seals, springs, small round balls to make the "detent" (for float) work. You can't see this end. This is the end that is effected by water that gets trapped in the housing.
You can google "two spool hydraulic valve' and get a picture of what it looks like. There is some variation in valves, but pretty much all operate the same.
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
1994 Peterbilt 379 Semi (A50514)
1994 Peterbilt 379...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2016 John Deere 410E 40 Ton Articulated Off-Road Dump Truck (A50322)
2016 John Deere...
