Kubota L4150 slow to start
   / Kubota L4150 slow to start #1
double hunter
Ford 1715
New to me Kubota L4150 that is slow to start, 2590 hrs, doesnt smoke, runs great, it is slow to start on initial crank up, I warm up the glow plugs for approx 30 secs but takes 3 or 4 attempts to get it started, checked the glow plugs and I think they are ok, has a hot battery in it, the fuel filter system had been removed and inline filter in place, i changed all this back to the original system, don't know if this would affect starting, the glow plug indicator on the dash gets hot but does not glow, looks like this tractor has a fuel transfer pump, just wonder if this could be weak or bad, tractor cranks and runs good after iinitial start up. Any help will be greatly appreciated.
   / Kubota L4150 slow to start #2
Do you get smoke at startup? Your manual lift pump maybe weak or failed completely. If your glow plugs are weak you will get lots of blue smoke and rough running on initial start-up. Does it make any difference if you pull throttle to full when starting and then move it to idle quickly as it catches?
Need more info:D
I just came in from trying it, I warmed the plugs for 1 min, hit the starter, got smoke from the start and it was like it was trying to crank, trying to crank, trying to crank , it started on the 2nd attempt but I started it about 2 hrs ago and its not cold down here today, how long should I warm the plugs, I may be worried about nothing but I have owned a couple Kubotas in the past and they all crank up immediately,
Kind of a update, out dragging my road this afternoon after monsoon went thru last and this thing doesn't crank good when its hot or cold, drug my neighbors road and he is a disel mech, he sez its not getting fuel like it should, I'm going to change out the fuel pump and see if this clears it up, if not it may be the injector pump, anyone ever had one rebuilt, what kind of cost is this???
   / Kubota L4150 slow to start #5
Hi
Just paid $1700 to get the injection pump rebuilt on my Cub 7274 (Mitsubishi)
   / Kubota L4150 slow to start #6
Before I messed with the IP I would check the mechanical lift pump that it is delivering and then do the injectors. And just for giggles new glow plugs.
I'm going to the Kubota place in the morning to get the fuel pump if they have one in stock.
   / Kubota L4150 slow to start #8
Glow plugs - you should only have to warm the glow plugs 5-10 seconds at most.
2005 Big Tex 10PI 16ft. T/A Utility Trailer (A49461)
2005 Big Tex 10PI...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2015 FREIGHTLINER CASCADIA DAY CAB (A51222)
2015 FREIGHTLINER...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
