Kubota L4150 Engine noise
   / Kubota L4150 Engine noise #1
ghhmtnboy
lafayette, new jersey
Kubota, Case, New Holland, John Deere
Hello,
Hope someone might have an idea here....
My Kubota 4150 has a intermittent growling (grinding) noise after it is started.
Becoming more frequent, sort of a dull rubbing sound. GGGRRRRRRRR
I suspected a starter problem (not disengaging), installed a new one, problem still there.
Machine is great shape, 995 hours, always stored indoors.
At a loss, any thoughts would be appreciated.
Thank you.
George
   / Kubota L4150 Engine noise #2
Water pump rub? Alternator?
Try taking the acc belt off and starting the engine. Don't run for too long, but a minute would be OK.
Does it do this when warm, cold, with load or not?
If maintained properly the engine should not be worn.
Hi,
You were 100% right, water pump rub!!!!!!!!
Took the belt off, felt play in the pump bearing, started the tractor, noise gone!!!!!
Ordered the new pump, will do an anti-freeze change at the same time.
Can't thank you enough.
Saved me grief and money (having to engage local Kubota dealer)
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2012 BRUMLEY MANUFACTURING DATA VAN TRAILER (A55745)
2012 BRUMLEY...
Caterpillar 740 HT-129 Off Road Water Truck, S/N CAT00740PB1P009728, Cat Turbo Diesel Engine,14,601 (A59076)
Caterpillar 740...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
