Kubota L4150 Engine noise
   / Kubota L4150 Engine noise #1
ghhmtnboy
lafayette, new jersey
Kubota, Case, New Holland, John Deere
Hello,
Hope someone might have an idea here....
My Kubota 4150 has a intermittent growling (grinding) noise after it is started.
Becoming more frequent, sort of a dull rubbing sound. GGGRRRRRRRR
I suspected a starter problem (not disengaging), installed a new one, problem still there.
Machine is great shape, 995 hours, always stored indoors.
At a loss, any thoughts would be appreciated.
Thank you.
George
   / Kubota L4150 Engine noise #2
Water pump rub? Alternator?
Try taking the acc belt off and starting the engine. Don't run for too long, but a minute would be OK.
Does it do this when warm, cold, with load or not?
If maintained properly the engine should not be worn.
Hi,
You were 100% right, water pump rub!!!!!!!!
Took the belt off, felt play in the pump bearing, started the tractor, noise gone!!!!!
Ordered the new pump, will do an anti-freeze change at the same time.
Can't thank you enough.
Saved me grief and money (having to engage local Kubota dealer)
TORO SAND PRO 3020 (A58374)
TORO SAND PRO 3020...
Quick Attach 84" Skid Steer Broom Attachment, S/N 103581, Asset# 73 (A59076)
Quick Attach 84"...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
36in Digging Tooth Bucket Excavator Attachment (A56857)
36in Digging Tooth...
PALLET OF TILE & SUPPLIES (A58374)
PALLET OF TILE &...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
