Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,813
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
Looks like the Kubota with BH is right about list - and less 10% would be $33,500 range.
They've gone up noticeably just in the last couple of years. When I was shopping less than 2 years ago, I got a quote on cabbed DK42SE for right about 30k. I think the pandemic likely has a lot to do with it (low availability).Dang have prices really went up that much. $29k for an economy L just don't seem right. What does kubotas website say msrp is on how it's configured?
15 years ago I bought the predecessor to the 3901. Which was the L3400. It was $17k out the door. HST was a $2000 option. So $19k. Which would be like $17k pre-tax. I know things get more expensive, inflation and all....but dang....70% in 15 years?
@RSR, Kubota tractor, with loader, 3rd function, is about $29000. Kioti tractor, with loader, 3rd function, is about $24000.
If you add the backhoe, Kubota is $37500, Kioti is $31000. It's approximate, plus minus couple hundred, wasn't sure how to apply rebates partially.
Kubota with backhoe should have at least 1 remote, I saw that you can configure them individually online. Most likely they just put on it what's needed for the backhoe. I guess one remote is plenty for a compact tractor anyhow, not sure which attachments you would need 2 remotes ...
The rest of the difference up to $13000 is from the other attachments.
DocTrac, I'm no master tractor guru by any stretch and only run my Kioti 3510SE HST (same tractor as 4010 with lower hydraulic flow rate but $1200 cheaper) on the occasional weekend over the last three years (150 hrs to date) but I have no regrets buying a Kioti. I found the same price shock as you in 2017. I think Kubota makes a quality tractor but your paying a premium for the name given their good track record. What eventually sealed the deal for me was realizing both Kioti and Kubota are made in South Korea and both companies make 99%+ of their own parts\components in-house vs. sub-contracting things out all over the place. Just my opinion this makes for a better product with less problems over time but it also means when you go to buy replacement parts their made by the parent company not by whoever in another country. That said, if you have a Kubota dealer near by you like and trust thats a big selling point over a Kioti dealer 100+ miles away. Good luck.This is DocTrac, new to the forum, checked this out and so much awesome info! About to pull the trigger on a compact tractor ...
Here's the situation: just received pricing for both Kubota L3901 HST and Kioti 4010SE HST compact tractors. Attachments and implements: tractor, 3rd function, canopy, backhoe, grapple, pallet fork, rotary cutter, box blade, disc harrow, rotary tiller. The configuration is virtually identical, I was very careful to match implements for both offers, e.g. shredders are both 2", 5', heavy-duty. I was shocked by the price difference: the Kubota dealer quoted a price that is $13,000 higher than the Kioti. That's thirteen thousand. Can somebody explain to me how this is possible???
