Kubota L3710 ?
/ Kubota L3710 ? #1
Lucky Dog
Bronze Member
Midland, MI
TYM 4820c
Any thoughts on a Kubota L3710?
I'm thinking about going to look at one, it is a 2003 and has 4100 hours.
Anything I should look for? Any problems? What do y'all think of that number of hours?
/ Kubota L3710 ? #2
If inside stored, well maintained AND owner operated only.....early middle-age.
Will not have the complication of Tier IV emission paraphernalia.
In most cases will pull 60" wide implements. Not enough power to pull many 72" implements, which you may have.
A bit lighter, narrower and less powerful than your MF65, but much more 'modern' and user friendly.
/ Kubota L3710 ?
Most L3710s were 4-WD. A few were 2-WD.
Thanks.
Interesting comment on the power, that is one of my concerns. Although, my 65 is getting very tired and I'm sure lacks the power that it once had.
I do have 6' and 7' implements. I'd rather not replace them, bit It really would not be a huge issue if I had to.
I'm really looking for something "newer" that my 1959, 4 wheel drive, and preferably a cab.
/ Kubota L3710 ? #5
I'm really looking for a tractor with a cab.
A cab weighs 400 - 650 pounds more than the same compact tractor in open station configuration.
You need ~5 additional horsepower for that weight and 5 more horsepower to power the AC when it is hot. ~10 additional horsepower, total.
Cab weight sits mainly on the rear wheels. Few 'load' the rear tires of cab equipped compact tractors.
I'm thinking about a Kubota L3710. It is a 2003 and has 4100 hours.
4100 hours / 19 years = 216 engine hours per year.
Pretty consistent with hobby farm use.
Kubota L3710
Kubota L3710 Power
Engine (gross):38.5 hp
28.7 kW
Engine (net):36.6 hp
27.3 kW
Gear PTO (claimed):31.5 hp
23.5 kW
Hydro PTO (claimed):30 hp
22.4 kW
/ Kubota L3710 ? #6
I've had an L3710 for 25 years, all my implements are 72" or bigger, with no issues. It is HST with a 72" FEL. I use a 72" tiller in heavy clay, a 78" snow blower in up to 4' of snow, I also have a 72" brush hog and 72" box scraper. All work fine with the L3710. The only thing I wish I had is a cab. I have 1500+ hours on the tractor, with absolutely no issues other than regular maintenance.
If the one you are considering has been well maintained, it has thousands of hours of life left.
