Kubota L3710
/ Kubota L3710 #1
kimw
Filion, MI
Kubota L3710
Best method for warming engine and hydraulic oil in cold weather?
/ Kubota L3710 #2
Hi. Welcome.
When I warm up in winter I run the PTO while running at 1500 to 1800 rpm. This moves the trans/hydro fluid warming it up. Operate the attachments to move the cold fluid into the warm.
/ Kubota L3710
Hi,
Thank you.
Thoughts on dipstick heater or block heater?
/ Kubota L3710 #4
Hi,
Thank you.
In my area block heaters are not necessary. In your area it would be a good idea unless the tractor is stored in a warm barn.
If you use synthetic oil a dipstick heater should not be necessary. I maybe wrong on this as I rarely have to start in temps below 10 deg.
/ Kubota L3710
Have been storing inside but thinking about storing outside. May try dipstick heater first.
/ Kubota L3710 #6
Welcome to the forum. :)
I'm going to move this thread over to the Kubota section in case anyone else finds the information useful.
/ Kubota L3710 #7
Even though Kubotas generally star good in cold weather;a block heater will help in the northern climates.My tractor sits outdoors and only gets plugged in if it's 20 degrees F. or colder.Not always needed but helps warm the oil and easier on the motor.
/ Kubota L3710 #8
Welcome!
Don't waste your time/money on a dipstick heater.
Block heater is the way to go.
Also 10W30 diesel oil,or 5W40 diesel synthetic oil would be prudent.
If you have a hydrostat,Super UDT2 hydraulic fluid will flow much better at low temps.
Don't forget to treat your fuel before it gets cold.
Good Luck!
/ Kubota L3710 #9
My dealer install block heaters on all L series and larger as part of the package.
5W-40 synthetic engine oil. Neighbor blew a crank seal on his NH using 15W-40. NH said they would replace one under warranty but don't do it again. They didn't specifically say that in their manual but through experience they rely on their dealers to spread the word.
Use Super UDT2 oil in the transmission. It has much better cold flow characteristics than plain UDT or any of the multi-purpose tractor hydraulic oils you find for lower prices.
I loved my L3710 but when I retired and moved up here permanently I traded for a cab. Wish I could have kept the smaller tractor - handy sometimes but couldn't justify it. Zero problems in 9 years, most reliable tractor I ever had.
Combine Tires (A65640)
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2013 CATERPILLAR 299D SKID STEER (A65053)
2013 CATERPILLAR...
2016 Great Dane 48ft. T/A Refrigerated Van Reefer Trailer (A64556)
2016 Great Dane...
2015 ALTEC DC 1317 CHIPPER (A65643)
2015 ALTEC DC 1317...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
