Hello,
I'm hoping to get some insight to a fuel related problem that I have been fighting for about a week now. I was going to bush-hog my property and my tractor started right up after a long winter nap. I made several rounds around one field, approximately 20 minutes worth and the engine lost power and slowed way down. I limped it back to my garage and checked the fuel filter. It was dirty so I changed it and thought that everything would be ok. Started working again and approximately 20 minutes later, same thing. I have now replaced the fuel filter, lifter pump, all fuel lines and still have the same problem. I even removed the fuel tank and removed a stick and an old spout from a fuel can from it. I removed the fuel filter assembly and disassembled and cleaned it. I'm getting kind of desperate and thinking it may be something inside the injector pump. I don't really know exactly how the fuel flows through the injector pum or how to remove and replace it. It seems like if I remove a line or filter or just let it sit for a while it will start and run for another short spurt.
Any help would be greatly appreciated.
