Kubota L35 4wd shift problem
/ Kubota L35 4wd shift problem #1
MGC Kubota L35
Boone, NC
Kubota L35
Hi Everybody
We have an L35 stuck in 4wd. The lever is still attached to the shift shaft going into the transmission, the shaft is turning but it does not contact anything. We're assuming that the L-shaped shaft is broken inside the case.
Does anyone know if the shift shaft can be changed from the top access of the transmission, or does the tractor need to come apart? We plan on fixing it ourselves, so any input would be greatly appreciated.
Thanks
FRONTIER HYD BALE SQUEEZE (A64277)
FRONTIER HYD BALE...
2001 Freightliner FS65 School Bus, VIN # 4UZAAXAK01CH91008 (A65563)
2001 Freightliner...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
10in. Auger Bit (A65640)
10in. Auger Bit...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
