Kubota L3410 hydraulic question.
   / Kubota L3410 hydraulic question. #1
fishingbucks
I recently bought a new valve with 3 spools to add grapple. Well, the new valve is bypassing fluid through the workports somewhere and causing loader drift I didn稚 have before. I知 sending the valve back to be fixed. In the meantime, I still need to use my tractor. How do I temporarily plumb the system to work rear lift? The rear lift works off power beyond port off of loader valve. With the valve removed, I have an 妬n line, 登ut line, and power beyond line. Do I just need to get a T fitting and hook up 妬n to 登ut and t off the power beyond line back to the port under tractor? Please help. Thanks
   / Kubota L3410 hydraulic question. #2
Connect the pressure line from the pump to the power beyond line (that would come from the loader valve) and cap the Tank line so you don't loose all the fluid.
Got it. Thank you!
2025 New/Unused Wolverine 36in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
1977 GMC GENERAL TANDEM AXLE DUMP TRUCK (A52577)
1977 GMC GENERAL...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
