Kubota L3410 hydraulic question.
   / Kubota L3410 hydraulic question. #1
fishingbucks
I recently bought a new valve with 3 spools to add grapple. Well, the new valve is bypassing fluid through the workports somewhere and causing loader drift I didn稚 have before. I知 sending the valve back to be fixed. In the meantime, I still need to use my tractor. How do I temporarily plumb the system to work rear lift? The rear lift works off power beyond port off of loader valve. With the valve removed, I have an 妬n line, 登ut line, and power beyond line. Do I just need to get a T fitting and hook up 妬n to 登ut and t off the power beyond line back to the port under tractor? Please help. Thanks
   / Kubota L3410 hydraulic question. #2
Connect the pressure line from the pump to the power beyond line (that would come from the loader valve) and cap the Tank line so you don't loose all the fluid.
Got it. Thank you!
2014 716PT Homesteader 7'x16' Box Trailer (A52384)
2014 716PT...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
