Kubota L3410 hydraulic question.
   / Kubota L3410 hydraulic question. #1
fishingbucks
I recently bought a new valve with 3 spools to add grapple. Well, the new valve is bypassing fluid through the workports somewhere and causing loader drift I didn稚 have before. I知 sending the valve back to be fixed. In the meantime, I still need to use my tractor. How do I temporarily plumb the system to work rear lift? The rear lift works off power beyond port off of loader valve. With the valve removed, I have an 妬n line, 登ut line, and power beyond line. Do I just need to get a T fitting and hook up 妬n to 登ut and t off the power beyond line back to the port under tractor? Please help. Thanks
   / Kubota L3410 hydraulic question. #2
Connect the pressure line from the pump to the power beyond line (that would come from the loader valve) and cap the Tank line so you don't loose all the fluid.
Got it. Thank you!
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
UNUSED FUTURE SKID STEER HYD MIXING BUCKET (A51244)
UNUSED FUTURE SKID...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
