Kubota L3400DT PTO not working
   / Kubota L3400DT PTO not working #1
kouterbrown
Mauriceville Texas
Kubota L3400DT
Just a little FYI i let my neighbor barrow my tractor to brushhog at his deer lease "Mistake" after running out of shear pins he installed a Grade 8 bolt :eek: Well i pulled shifter cover off gear box and pulled PTO lever gears are meshing well & turning BUT output shaft is not turning. Pulled output shaft out of the back of the tractor & it & the splined coupling are fine, looking for any help or advice on splitting the tractor just behind the gear box or any one who has experianced this problem.
   / Kubota L3400DT PTO not working #2
Not sure what the problem is?
Proly get more help posting in the Kubota forum.
   / Kubota L3400DT PTO not working #4
If tractor pto shaft doesn't turn under power when it's engaged I'd guess pto clutch hub is stripped from pto clutch plate.
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
Mi-T-M AS6-HE15-120M 175 PSI Air Compressor (A50322)
Mi-T-M...
2011 Liebherr L586 (A52748)
2011 Liebherr L586...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2005 International 7400 Cattle Truck (RUNS)(TITLE) (A50774)
2005 International...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
