Kubota L3400DT PTO not working
   / Kubota L3400DT PTO not working #1
kouterbrown
Mauriceville Texas
Kubota L3400DT
Just a little FYI i let my neighbor barrow my tractor to brushhog at his deer lease "Mistake" after running out of shear pins he installed a Grade 8 bolt :eek: Well i pulled shifter cover off gear box and pulled PTO lever gears are meshing well & turning BUT output shaft is not turning. Pulled output shaft out of the back of the tractor & it & the splined coupling are fine, looking for any help or advice on splitting the tractor just behind the gear box or any one who has experianced this problem.
   / Kubota L3400DT PTO not working #2
Not sure what the problem is?
Proly get more help posting in the Kubota forum.
   / Kubota L3400DT PTO not working #4
If tractor pto shaft doesn't turn under power when it's engaged I'd guess pto clutch hub is stripped from pto clutch plate.
1274 (A50490)
1274 (A50490)
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb. 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52141)
2023 EAST TEXAS...
2012 Ford F-450 XLT (A50120)
2012 Ford F-450...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
Kubota 29" Backhoe Bucket (A50774)
Kubota 29" Backhoe...
