kubota l3400 start issue
   / kubota l3400 start issue #1
jedwa1216
kubota l3400
My Kubota has been having starting issues for a year or so. It finally has got so bad (wont start 80 percent of the time) that I have to figure it out.
I have replaced the battery and ignition switch but neither fixed it. The start relay tests good. I have been searching for bad connections but no luck.
I have found that when I turn the key to start, battery voltage drops from 13 to 8. This also happens when I read the voltage at terminals 2 and 4 on the start relay with the key at start.
The safety switches and circuits all test good. Any help is appreciated.
   / kubota l3400 start issue #2
Sounds like it could be the chassis ground. Have you followed the ground cable to the location on the chassis and ground or sanded the cable terminal and grounding area clean?
   / kubota l3400 start issue #3
Check for rodents chewing.
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
Electric Concrete Mixer (A51573)
Electric Concrete...
2021 John Deere 410L Backhoe (A53342)
2021 John Deere...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
