Kubota L3400 Garden Advice
   / Kubota L3400 Garden Advice #1
puttering
2007 Kubota 3400HST
I have a Kubota L3400 4wd. Last year we planted a small garden and had lots of fun with it. The weeds are terrible where we live and became a huge problem. We tried to manage it by hand but simply did not have the time to work it to make it look good and produced like it should have. I would appreciate any suggestions or advice on setting up a garden for this year and all the ways my tractor can be utilized to make it easier. I have a disk, front end loader, box blade. I am wondering if an attachment or attachments can be used to set up my rows and then routinely clean them with the tractor. Space is not a problem and we would like to have a larger garden.
Thank you in advance for any and all suggestions and ideas you may have to help.
   / Kubota L3400 Garden Advice #2
If you want the seed bed hills you can find or build a hiller. It may also be usable to weed at least some of the rows.
   / Kubota L3400 Garden Advice #3
I use a three point cultivator;it has six tines,removed the center two and straddle plants.At least until they get too tall.
   / Kubota L3400 Garden Advice #4
I added a hiller to my cultivator and remove when weeding.
   / Kubota L3400 Garden Advice #5
Use straw for mulch. Put it on really heavy(so no light can reach the ground). That will conserve moisture in the ground and keep the weeds at bay. Care must be taken when doing this though, if one mulches too early, the ground won't warm properly.
And I also stole 'nybirdman's" idea. That implement resides at my BIL's place as he plants the potatoes and corn(I plant the rest of the stuff).
   / Kubota L3400 Garden Advice #6
Just wondering if you realize your disk are on backwards, the concave side facees into dirt to form hill.
   / Kubota L3400 Garden Advice #7
i use my tractor and 5` rototiller for getting the garden ready in the spring, then i plant my rows 2` on center and use my troybilt tiller in between the rows to keep the weeds to a minimum.
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2008 JOHN DEERE 6330 LOT NUMBER 98 (A53084)
2008 JOHN DEERE...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
