Kubota L3301 won't throttle down
   / Kubota L3301 won't throttle down
What year is it? If I recall correctly they have a 5 year warranty.
unfortunately the warranty is expired. I basically only use it for mowing about 4 acres
   / Kubota L3301 won't throttle down #12
Gonna have to bite the bag then. Most dealers charge around 100 bucks just to plug in and that don't include any repairs.
   / Kubota L3301 won't throttle down #13
The tractor has about 375 hours on it and never had a problem till this. It will throttle up, so I don't think it's the cable, but won't idle down past about 2000 rpm. No regen icon flashing.
What do you suppose is up with that ?
Does it have a spring to help it return to idle? could have broken and need replaced.
Actually, when I fired it up a couple days ago to load it for a trip to the dealer, it idled fine, same as it always has. It's been so hot here in Alabama that I have been putting off cutting the rest of the pasture, hoping for a cooler evening to do it, but hopefully it will continue to idle properly. My guess is still computer.
15200 (A56857)
15200 (A56857)
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2225EB000634, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
1997 DORSEY AIDT-LSCG 53 FT DRY VAN TRAILER (A59575)
1997 DORSEY...
5004 (A55851)
5004 (A55851)
2011 Ford E-350 Cargo Van (A56858)
2011 Ford E-350...
Lot 246- LINCOLN MARINE STYLE WELDER SHIELD ARC SAE-400, DIESEL, HOURS SHOWING: 3,157 (A59213)
Lot 246- LINCOLN...
