Kubota L3301 won't throttle down
   / Kubota L3301 won't throttle down
What year is it? If I recall correctly they have a 5 year warranty.
unfortunately the warranty is expired. I basically only use it for mowing about 4 acres
   / Kubota L3301 won't throttle down #12
Gonna have to bite the bag then. Most dealers charge around 100 bucks just to plug in and that don't include any repairs.
   / Kubota L3301 won't throttle down #13
The tractor has about 375 hours on it and never had a problem till this. It will throttle up, so I don't think it's the cable, but won't idle down past about 2000 rpm. No regen icon flashing.
What do you suppose is up with that ?
Does it have a spring to help it return to idle? could have broken and need replaced.
Actually, when I fired it up a couple days ago to load it for a trip to the dealer, it idled fine, same as it always has. It's been so hot here in Alabama that I have been putting off cutting the rest of the pasture, hoping for a cooler evening to do it, but hopefully it will continue to idle properly. My guess is still computer.
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
2011 Ford F150 XLT Pick Up (A55272)
2011 Ford F150 XLT...
EZ-GO Freedom SE Electric Golf Cart (A57149)
EZ-GO Freedom SE...
Case IH 160 Puma (A57148)
Case IH 160 Puma...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
