Kubota L3200 stalled after running kerosine
   / Kubota L3200 stalled after running kerosine #21
JWR, best answer yet.:thumbsup: EDIT:corrected username
   / Kubota L3200 stalled after running kerosine #22
diesel85: ................ The numbers are in microns (millionths of an inch.) ...........
Pretty good story thanks.
However 1 micron is one millionth of 1 metre (or meter if you prefer), not millionth of 1 inch.
Cheers!
   / Kubota L3200 stalled after running kerosine #23
Had the same problem with my tractor a year ago when I got bad fuel. When I would get under a little load it would loose all power and die.... I had to purge the fuel tank and replace all the fuel filters. One of the two filters was pretty plugged up. I lost my electric lift pump a few months later so I modified the fuel system and put filters where I could get to them easily and am rabid about keeping them clean. BTW it is a BX25D tractor which is baby compared to yours.
Thanks guys.
Total run time was about 5-10 minutes after adding kero. Temp gage was about 1/4 up from dead cold. Just in normal operating zone.
After draining the tank, changing the filter and refilling with diesel, another 5-10 mins. Same after I came back and ran it again. It did feel down on power even after refilling and up to the point it choked.
Total run time on questionable fuel, less than 20 mins.
I'll try draining the tank and cleaning everything out including purging the lines. . and I'll check injector spray. I ordered a set of injectors (returnable) just in case.
I would have thought dirt or water would have been caught by the filter/separator, as that's kind of it's job.
I'll keep this thread updated.
   / Kubota L3200 stalled after running kerosine #25
   / Kubota L3200 stalled after running kerosine #26
I personally had my tractor gel up when running a anti gel additive. Kero works better.
   / Kubota L3200 stalled after running kerosine #27
Thanks guys.
maybe you'll want to try purging each injector line into a container, to clear out any leftover bad fuel in the lines..
   / Kubota L3200 stalled after running kerosine #28
A BX, new or older is still pretty basic and forgiving of fuel. They have no emissions systems.
New BX tractors have emission controls, just relatively simple controls to meet Tier 2 emission requirements.
New BX tractors are Tier 4 exempt but not Tier 2 exempt.
   / Kubota L3200 stalled after running kerosine #29
Is it possible that the injector pump can't compress that thin kerosene? Short of a vaccume leak that might also only develop on account of thinner fuel, it's the only thing I can think of.
I have seen wire drawing machines that used Kerosene as lubricant, so I am guessing it does have lubricity.
   / Kubota L3200 stalled after running kerosine #30
Hmm. I thought they all met Tier 4 now, but in their own way. Smaller engines didn't need the extra measures to meet tier 4. (this is how I understood it)
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A57453)
1996 International...
20ft x 7ft Bi-Parting Galvanized/Powder Coated Metal Gate (A59225)
20ft x 7ft...
2006 SKYTRAK 6036 TELESCOPIC FORKLIFT (A52708)
2006 SKYTRAK 6036...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
